The 100w of
solar per 100Ah if
battery is a decent rule of thumb for favourable conditions but extra batteries are only relevent if you have spare capacity to charge them and the OP specifically mentioned those less than perfect periods. The rule of thumb dates back somewhat to lead acid and in real terms of capacity lithium out performs LA considerably Ah/Ah. I've got 200Ah of lithium and 240W of
solar and personally I find I need more
solar, and much more
solar in less than perfect conditions.
Indeed, you understand the situation.
I know you've had a bad experience previously WRT discharging a LFP too far previously Steve but you really can take them lower than 70% discharged, you'd get nearly an extra 30% capacity from your
battery if you took it down to 90% instead and that's perfectly acceptable.
Well it isn't that I had a problem discharching them that low, my manufacturer specifically told me I could discharge to 0% if I wanted. The problem was I was not aware that you are unable to recharge it if you deplete to 0% as it will not be able to power the components that recharge it!
I was under the false impression that the
solar charge controller would power itself and as soon as the sun came up the
battery would come back to life. Not so! Had to return to shore to remedy that but lesson learned.
I had considered a low voltage disconnect to prevent that again but I watch it so anally day by day now I doubt I would let it happen again.
You ask for our opinions, your choice if you take any or none.
Yes, thanks for your real world example. Useful data there.
I have 300W
solar on the roof (2 x 150W panels in parallel), I use diesel heater for warmth and unless
solar is good I use gas for cooking. I have a 110ltr compressor fridge and my 12V usage is approximately 65Ah per 24 hours. 1 have 2 x 100AH dumb
lifepo4 batteries fitted at the end of 2018 and still perform as on day 1.
I like to park off grid for a couple of weeks at a time summer and winter usually all in the UK. I am not full time but usually do around 10 months a year in the van.
A typical year I am good on
solar for around 7 months which leaves 5 months I could struggle. I carry a generator and have 2 x 30A mains chargers to top up my
battery as and when needed. Genny is much cheaper than extra servicing or repairs to a big diesel engine, downside is I have to carry it and I need to carry petrol. Neither are a problem for me.
Hmm, for me I have only struggled for december and january. Probably the difference is you have higher consumption. I only run the bare essentials, no fridge or other 'luxuries' but laptop I must confess is my vice as an inveterate surfer. I use it for hours a day but it is not frivolous stuff. It is nearly all posts like this and other research for off grid living. If not research then buying the various accoutrements for the lifestyle.
Can you tell me how much of the year your 200Ah stays topped up to nearly full/full? As your
solar is the same as I have currently it is a good comparison. I question how much use the second hundred Ah would be in, at a guess, months September, October, November. December and January it is a given
solar is off the table. Then January, February, March.
I only bought the 3rd panel, bringing me to 300W, before winter and of course was disappointed to see it didn't help nearly at all for then but as soon as January came around I do recall it shot up like a phoenix from the ashes and I was not having to watch my usage again almost overnight.
I don't remember how long it took though until I was hitting full
battery days. Also this was before the extra load I have added of about 12Ah per day which will be a sizeable hit.
I think I might go with no action while we come into autumn and then see how I fare. It will only be a day's job to add another
battery so can just get it as the situation may arise. If I am not still getting full
battery days with just one then I will have saved a few hundred quid!
Before I carried the genny I was snowed in somewhere for 8 days, I had to run my engine for an hour each day to keep a bit of power with the fridge switched off. When the roads were opened again I drove out and for the first 6 or 7 miles I had lots of smoke coming out the van exhaust, that was enough for me to not want to do it as a normal thing (that was sat with food on throttle holding it at 1200 rpm as well).
Yes this was something I investigated too but did not like the idea of having to deal with two different fuel types and diesel generators being so much more.
Last Winter I spent in Scotland, weather wasn't too bad, I didn't get snowed in anywhere but was very cold and snow about. I ended up moving every day or two instead of sitting for weeks and I didn't need to use the genny at all.
Do what works for you
Of course this reminds me that one can always just change their habits to tighten their belt on the consumption front. It is my laptop that drinks all the juice from day to day so I can just decide to do other stuff.
Of course it happens to be the time of year you want to be inside more than doing stuff outside away from a screen but so it is.
I was working outside most of winter. In fact I didn't have any heating at all for much of the coldest times when it was down to the minus figures because of course the dc-dc charger konked out during the holiday period when everywhere was closed to couldn't send it for inspection but that was also the time when I ran the
battery to nothing leaving me unable to recharge it until I got to mains to give it a boost.
That was unforeseen though and not fun but point is I was outside and working during the coldest times and soon warmed up. It would not be a hardship if I still had heating in the van to come back to once I finished for the day. That time I would just dive into my double sleeping bags!
