wildebus
That will be a 100W or 120W Panel you have there.We can't find any information on the solar panel except that it measures 9x4 squares ie 36 squares but my husband has measured it as 54cmW x 120cmL
sorry, but not a reliable way to find the power of a solar panel as too reliant on external influences (the sun!) and the internal influences (the solar controller).You can measure the volts and amps to find the wattage.
That is a very nice Fridge-FreezerThe fridge is a Thetford T2090
Depending on which model you have, you may be able to reduce the power consumption by turning the freezer section off if not needing it (yes, you lose the freezer, but means can extend your time off grid).
If you haven't checked already, have a look at this PDF - https://www.jacksonsleisure.com/content/pdf/thetford/T2000-Series UM EN.pdf . There is a section in there regarding the drip-tray.
In the summertime, a 100W Solar Panel (if not under shade!) could easily keep up with the demand of a compressor fridge. As has been mentioned, it is also down to what other power draws you have to if it can keep up with everything. Really is impossible to say as everyone uses power differently. Some people on this forum seem to go weeks with a set of 4 AA batteries (ok, slight exaggeration!) and others (like myself) seem to drink batteries.
It really doesn't matter what others tell you what to expect based on THEIR use - THEIR use is not YOUR use. But having said that, the chances are the single battery fitted in a commercially made campervan is most unlikely to be adequate to run a compressor fridge on-grid for any real length of time.
Your Fridge is spec'ed at 280Wh/24hrs. That is in perfect conditions and probably assumes doors are never opened, etc. The amount of cold lost when you USE the fridge in a normal way means that is probably more like 400Wh/24 Hours or more. (My own compressor Fridge Freezer uses just under 50Ah/24 hours - around 600Wh).
If you have a fairly typical 100Ah Lead Acid Battery, that has a TOTAL capacity of 1200Wh, and if you don't drain past 50% (a commonly quoted suggestion), that leaves you with a USABLE capacity of 600Wh available. So even without using any other thing in your van, your fridge will be hard pushed to get you a weekend of off-grid camping (assuming that battery).
Reality is - IMO - if you want to off-grid with a typical compressor fridge, you will need more battery than you likely have; you could benefit from more solar if you are wanting to do more than just run a fridge; and to make the best use of more solar - or even the solar you currently have - the chances are you need a better solar controller to harness the solar energy from the panel. (converters tend to fit the cheapest, most basic controller, rather than the best performing ones).
