chipvan
I have read a few comment regarding battery to battery charges but no one mentions how these effect the Sargent unit (if one is fitted) ?
I have the same problem as many other who use there motorhome all season, the solar panel on the roof does not generate much power in the winter months and with power consumption higher due to blow air heating, lights etc, our 2x110amp leisure batteries only last for about two days.
Running the engine or moving location does charge the batteries but not enough. Not really surprising if you look at the 20amp fuse Sargent fit and the small cables.
I don't want to add another batterie as it will be two years newer then the matching pair we have, plus the extra weight.
Sterling say pull the fuse out of the Sargent unit that feeds the leisure battery from the alternator then fit the battery to battery charger between the vehicle battery and the leisure batteries.
Has any of you with newer Motorhomes with a Sargent unit done this and fitted a B2B ?
I don't want to carry a generator around and a can of petrol, as we don't have a garage, weight would also be an issue as well as security. I like the idea of LPG instead of petrol for the generator, as we have two refillable bottles, but why not use the big diesel generator that is factory fitted to our motorhome and it comes standard with an alternator (the engine) ?
Before you all comment we do have LED's fitted and don't watch much TV, but we do have teenagers with phones and iPads that seem to always need charging.
