trevskoda
Metal frame can be live if unit at fault, even if switched off.How? "UNLESS YOU STICK YOUR FINGERS IN WHERE THEY SHOULD NOT BE"
Wasting your time Trev.Metal frame can be live if unit at fault, even if switched off.
Unfortunately you committed the cardinal sin where electricity is concerned and didn't test first. Rightly or wrongly a lot of lighting circuits in particular use switched returns. Neither can you go on the colour of wires and make assumptions.I do know what I am doing I did it for 35 years, so did Johnny Doyle he was an electrician as well as a football player, paranoia did not kill him, electricity did.![]()
You just committed a cardinal sin wiring a 500w light to a 6amp lighting circuit. It was a ring main and I had switched it off at the consumer unit. The whole ring main was thus wired wrongly. This came to light after the event.Unfortunately you committed the cardinal sin where electricity is concerned and didn't test first. Rightly or wrongly a lot of lighting circuits in particular use switched returns. Neither can you go on the colour of wires and make assumptions.
No you thought you had switched it off, You still didn't test.You just committed a cardinal sin wiring a 500w light to a 6amp lighting circuit. It was a ring main and I had switched it off at the consumer unit. The whole ring main was thus wired wrongly. This came to light after the event.
I don’t know a spark who has never been plated.I have the same feeling. With 35yrs experience you managed to get a good belt . Leaves a lot to be desired.
The vast majority of sparks would have done what I did. That was the only time I ever saw a ring main wired the wrong way. Wiring reverse polarity is dangerous. If you don’t reckon so then so be it.No you thought you had switched it off, You still didn't test.
I never said it wasn't dangerous, stop making assumptions it's simply shocking.The vast majority of sparks would have done what I did. That was the only time I ever saw a ring main wired the wrong way. Wiring reverse polarity is dangerous. If you don’t reckon so then so be it.
I managed to shut down an entire Waitrose warehouse once when swapping a lightbulbReverse polarity kills people even electrical engineers, every year.
I was replacing a security light years ago that was wired wrongly. I was thrown off a ladder when I went to remove the wiring.
When you switch of an appliance with a single pole switch you have every right to expect you have switched the positive. There was a famous case years ago when a Celtic football player Johnny Doyle was killed due to reverse polarity whilst working on electrics in a metal trussed roof.
Johnny Doyle (Scottish footballer) - Wikipedia
en.wikipedia.org
You are assuming wrongly I said that, now that really is shockingI never said it wasn't dangerous, stop making assumptions it's simply shocking.
David, the light was earthed.I managed to shut down an entire Waitrose warehouse once when swapping a lightbulb
Lightbulb was the indicator bulb on a tape drive unit on a mainframe computer. Computer was American and had US wiring colours and whoever installed it had swapped 'hot' and neutral wires over and apparently never tested?
So switching the main computer power inlet off didn't isolate the live, and changing the indicator bulb (240V in those days) I must have managed to short to ground through myself.
Got a fair shock and the ELCB (as the 'RCD' was back then) shut everything down and it was the week before Christmas. I was as popular as a Russian in Poland.
Something I always do as a final cursory check when working on anything that has the potential () to have mains power, such as a metal frame or supports ... tap on it with the back of the hand before holding with the front. electricity makes the hand close and you can end up grabbing something that is live and you cannot let go!
PS. To those who might have said "well, you should have unplugged it", what you can and can't do depends on the equipment.
A REAL computer is often hardwired with the lead going into the switch in the cabinet (nothing to unplug) and the cable comes up through the floor, so cannot trace the lead, and you do make an assumption that something was wired up correctly before you tell the manager of a big warehouse you want to shut the building down before you change a bulb.
Arguably nothing, it was him who caused the issue.So arguably it was the tampering homeowner that caused the issue along with your lack of adequate testing, ie complacency?
Not saying sparkies don't get complacent because we all know they do but ultimately if they get a belt/killed surely as the professional they should have had the situation covered?
If someone working on something (nice and ambiguous there) checked every single thing unrelated to their job but could be consequential to what they are about to do before they started, every piece of work would take so long and be so expensive nothing would get done.So arguably it was the tampering homeowner that caused the issue along with your lack of adequate testing, ie complacency?
Common sense.If someone working on something (nice and ambiguous there) checked every single thing unrelated to their job but could be consequential to what they are about to do before they started, every piece of work would take so long and be so expensive nothing would get done.
Got a knocking from the engine so you go to the garage. Should the mechanic before he goes out on a quick test drive check all the wheels nuts are tight and the brake pads have enough meat on them?
Should someone going up on a roof to replace a tile first go in and check the roof trusses are ok? and check the walls that support them are good? and the mortar that is securing the bricks is not crumbling? and the foundations are secure? and and and.
In all work, reasonable assumptions are, and have to be, made.
You don’t know WATT you are talking about TrevShocking thread it has turnrd out to be, but its ones ohms fault if you get a belt.
Currently he does anywayYou don’t know WATT you are talking about Trev![]()
