No the small leads go to fuses, one fuse for each utility, then one big feed from battery to pos termanal on the board, neg from bat to neg on f blockSo, all the small positive leads from the
+ battery go to the fuse holder positive and all the small negative feeds that currently go to the Victron Shunt go to the fuse holder negative.
Then just one + cable from fuse holder to + battery terminal and one negative from the fuse holder to the out of the shunt?
That would look prettier!!
I so appreciate all your help in this as ever.
Regards
Martin
Only require to break the pos line in.I originally fitted an isolator in the line from solar panels to solar controller but after a while I fitted a 2 way blade fuse holder instead. I put both + and - cables through a fuse each. Been like it now for years and doesn't seem to cause any problems
Not at 50 amps, only low ampage utilities like lights usb plugs toilet flush and a radio etc, max i think is about 30amps, most of mine are 5/15 at most.
I know that Trev. I was mis-remembering anyway. I knew I had used both fuses but I was forgetting I have two sets of cables coming from my panels, (I use two controllers). It is only positive I fused, one for each panelOnly require to break the pos line in.
Just for info, the standard size Blade ('ATO') Fuses go up to 40A. They go down to 2A as the lowest I think (never seen smaller than 2A).Not at 50 amps, only low ampage utilities like lights usb plugs toilet flush and a radio etc, max i think is about 30amps, most of mine are 5/15 at most.
You best bet if not sure about electrics is get someone who knows to look over it.
This is always an issue because you can't get a multi-purpose fuse holder that covers the whole range. Looks like you're going to have a blade fuse box and then a couple of separate large single stand alone fuses. If you were fastidious you could buy a 2 or 3 way ANL fuse box to do the big stuff.but if you mount the large fuses side by side neatly it's nearly as neat.
I would not use the breakers instead of fuses. unless you get decent branded ones (which are much more expensive then the ones on ebay or the slave-trading temu, they will either trip at a lower current then specified, or they will never trip.As above, hence i showed the trip type fuses, i use one for my fridge, always go a bit bigger, so if you require a 30 anp trip fit a 40 or bigger if powering a induction motor like a fridge or m wave.
What you can do is connect just one (fat) cable from the battery to the 50A vanbits fuse and then loop out of the fuse input and into your new ANL fuse and then loop again out of that and into your blade fuse box. That way you only have one feed off of the battery![]()
