marchie
The Fiat Ducato Owner's Manual [Post 2016 IIRC] contains a warning/instruction to turn the ignition on, and wait 5 seconds for the warning lights to extinguish before starting the engine. I the ECU is about to blow, the Airbag Red Warning Light will remain illuminated, so turn the ignition of and get an EHU charge into the Vehicle Battery ['VB'] before proceeding. I found out the hard way in November 2021 what happens if you don't follow this procedure, 6 days after having the VB changed because it was almost 5 years old. Unfortunately, the new VB was duff, and the garage refused to contribute to the repair bill. The total bill, including a new Yuasa VB and a Diagnostics Trace to find a parasitic drain that was taking current FROM the VB and passing it to the LB, ruining a 2nd replacement VB in the process, was £1335, including the AMT 12-2 Trickle Charger that David [Wildebus] recommends. Before the software update that permits a permanent trickle charge was available, David hard wired a switch to the outside of the Battery Box to allow me to leave the permanent trickle feed operating
Steve
Steve
