smart ass required...CI riviera 181 van
  • Thread starter Thread starter ajs
You could always buy a new van and let the new owner clear the blockage in your current one. :rolleyes: :D
Just me sticking my oar in but I was told by some smart git to pour a whole bottle of cheap Lidl/ALDI Coke Cola down the two sinks and shower tray and leave it for a couple of days. I did this on holiday in spain and it certainly worked. It brought all the sh*t of the inside of the waste tank and the smell went right into the french mans caravan that was parked behind me.:D:D Also told to use cheap orange (dilute to taste stuff) this works to clear like coke (not as good) but it keeps the tank and pipes smelling nice (use if you have nasty niffs coming up plugoles
Have also on occasions used the sink/drain cleaner (mr muscle) poured the whole contents down the sink, waited a few minutes then poured boiling water after it.:rolleyes: Push and hold a big cloth over the plug hole just in case it blows back.:eek:
do me a favour.:cool:.. pop into yer van and try a bottle of bleach
with an after flush and tell me if that works ;)
cus that's what i was thinking of doing but i'd rather you flook your van up trying it first...:D
ffffanks :D
regards :rolleyes:
aj
Must be all that Turkey and Beef fat from the New Year meet:D
Mr Muscle does the trick, then plenty HOT water to flush out:p
Good luck.
kinelll :rolleyes::mad::(
cumon you lot... gime an ammer solution will yer ...:mad:
regtarts
aj
hi,
sounds like your outlet pipe is bunged up.
to cure this, just open the outlet pipe,
turn on the garden hose full strength
and hold it up into the outlet.
this forces the gunge back into the tank
and lets the water run free
repeat a few times till the waste water runs clear
I do this 2 or 3 times a year
works for me!
sounds like i'm gunna get very wet and covered in gunge...:eek:
:eek:..can't wait till the mornin now...:rolleyes:
regards :confused::o
aj
Could be a bunged up outlet if AJ is comfortable that water is in there and its exit is blocked..
Alternatively it could be electrics after all it is a CI.
My bugger can dump all the grey watter and still the lamp on the the control panel lights up when it is empty.
Particularly after rain or a cleaning in other words after the tank area has had contact with water.
Channa
smarta** required
hi ajs
go to a garage with an air
line, take the end you normally check the tyres wif stick it in the end of your waste pipe wrap a damp rag around it, with the waste lever open, and blow the air line, remove and repeat if needsbe.
good luk hogwillis
AJ stop wasting yer time on here.. Yer supposed to be out there doing doing using all the tips and remedies you've been given to clear out yer back passage!! We're waiting impatiently to hear how you got on..wether you got covered in gunk and stuff. So get on with it man!!:D
yes mum... on my way.:o
.... oooohh sheeet:eek:.... i'm shakkin like a don't know what :eek:.. :rolleyes:
(up norff sayin is that btw)
regards:p
aj
We can only hope that someone video's it all and puts it on youtube.
nope... didn't get the camera out... everything else.... ohhhh yesindeeeedie..:D
air compressor... hose pipe into karcher, karcher on and primed on full blast setting.
Stick, screwdriver.. Round long file... and some bent wire..
oh... and a can of WD40...
opened pulley thingee... nuffin...
poked it with wire stuff... lost it inside... how the friggin ell am i going to get that out now...:mad:
poked it with stick, file... nufffin...
stuffed karcher up it.... blast blast... blast...
filled the friggin thing from the outside almost.. it then pithed out...:eek: probably just the stuff i'd blasted in mind.
200psi compressor.... up she goes.... filled the tank with air forcing the remnants of what i'd just put in with the karcher… out...
all over the palace… including me....bastid ...bastid... stink to high heaven now...:mad:
anyway... came to the conclusion the daft thing was empty all along :eek:
and the fault must have been to do with electrickery...
(friggin hate chinamen me.... smartasses):mad:
then i come across a bunch of wires all pretty colours and a couple of black things that they all went into...not very well insulated either
so i reckoned that the problem was this lot:confused:
how the floook you find out which wire i don't know so i cut the lot away
silly things… were hanging around getting covered in watter anyway
guess what... no more light problem.. it's out...problem solved:D... yipeeee
mind you.. so are all the light at the back of the van...:o
problem to sort tomorrow... probably blown a fuse of the bulbs are knackered...
friggin hate vans me... with a passion...I’m avvin that hotel
refurks:p
aj
Nope... Didn't get the camera out... Everything else.... Ohhhh yesindeeeedie..:d
air compressor... Hose pipe into karcher, karcher on and primed on full blast setting.
Stick, screwdriver.. Round long file... And some bent wire..
Oh... And a can of wd40...
Opened pulley thingee... Nuffin...
Poked it with wire stuff... Lost it inside... How the friggin ell am i going to get that out now...:mad:
Poked it with stick, file... Nufffin...
Stuffed karcher up it.... Blast blast... Blast...
Filled the friggin thing from the outside almost.. It then pithed out...:eek: Probably just the stuff i'd blasted in mind.
200psi compressor.... Up she goes.... Filled the tank with air forcing the remnants of what i'd just put in with the karcher… out...
All over the palace… including me....bastid ...bastid... Stink to high heaven now...:mad:
Anyway... Came to the conclusion the daft thing was empty all along :eek:
And the fault must have been to do with electrickery...
(friggin hate chinamen me.... Smartasses):mad:
Then i come across a bunch of wires all pretty colours and a couple of black things that they all went into...not very well insulated either
How the floook you find out which wire i don't know so i cut the lot away
guess what... No more light problem.. It's out...problem solved:d... Yipeeee
mind you.. So are all the light at the back of the van...:o
problem to sort tomorrow... Probably blown a fuse of the bulbs are knackered...
Friggin hate vans me... With a passion...i’m avvin that hotel
refurks:p
aj
numpty.....
:D Job for next Saturday then.
note to me: Remember to pack soldering iron
;) such a pity, we'll never see that story on You Tube. :p:D:D
AJ: BTW could recomend: "Electrics for dummies" ;):D:D:)
to be continued ???
aj
:rolleyes:Channa
Btw ...I am friggin useless at suggesting a cure, Mine lights up goes out lights up again like Blackpool it is :mad:
I reckon the electrics were designed by a monkey who had spent a night indulging in recreationals with me frog.
Channa
