UFO
Water runs off the bathroom sink tap, when turning it on and off with wet hands, under the sink rim and finds its way into the cupboard under the sink.
I wanted to take the sink out and reseal it. Looking underneath I can't see any fixings so I assume that it just glued down. I can get a spatula blade under most of the sink rim, as in the photo, but not all the way round - but the sink is stuck fast.
Also I would like to replace the shower hose as the outer has become broken exposing the inner hose, currently 'repaired' with electical tape. The shower hose OD is around 13mm, which is a bit smaller that the standard UK shower hose. Neither end will pass through the fitting that the hose passes through. So how do you replace the hose? If I can get the sink out there will be room to investigate the fitting.
It is a a 2009 Fiat Ducato Adria Twin but the bathroom may be the same in other Adria models of the same age.
Anyone tackled these job or have any ideas.
thanks
thanks
