Bigpeetee
Some very 'sound' advice OM G6FDO dah-di-dah
Captain Biggleslane:
One of the longest CW call signs!! Great for QRSS/M
Downside of having antenna on top of roof of motorhome, it can hit low bridges, branches etc
It's on Windows 8.1 so hopefully will be worth a go.
Just the thread I need, I need to replace the aerial on my Autocruise Starfire 2002, it's mounted on the o/s front wing, how do I get to underneath to remove it and fit the new one, any help appreciated.
What about an antenna with a magnetic base that you can install/remove when you want? The only con would be that you'd have to run a wire through the window. The trade-off is that you don't have to drill through the roof. £3.99 on Amazon UK.
I use my status tv aerial - it will receive very weak signals esp if power is switched on. Ok when driving as well.
Amplified internal antenna are all rubbish. However nowadays even external antennas can't reach a proper signal.
FM coverage has worsened over the years. Broadcasters don't invest in FM repeaters and in some cases switch to web-only (Jazz FM is one case). DAB is even worse.
I am not mobile at the moment but I get a good FM reception by plugging a rtl-srd device like this:
Amazon.com: RTL-SDR, FM+DAB, DVB-T USB Stick Set with RTL2832U & R820T. Great SDR for SDR#, HDSDR: Electronics
into my laptop and the install SDRSharp. The included antenna is just ok, but one could attach a longer piece of wire. With a decent antenna, even a couple of metres of wire hanging out your window, and that dongle, I can get good signals.
If instead of SDRsharp you install the included software (BlazeVideo), then you get a few digital radios and many digital TV stations.
Have now installed the drivers for the plug in DVB-T+DAB+FM device and BlazeVideo but it keeps saying "No Signal" when scanning for channels. I also bought an aerial adaptor lead for it so I can attach my Status to it but still getting no signal.
MCX To Coax Socket Adaptor Lead Convertor TV Card DVB-T To Coax Aerial Female | eBay
What am I doing wrong?? :mad2:
Are you keeping the small antenna fully outside the vehicle? Have you tried at home from the 1st/2nd floor? How rural is your location?
But have you tried scanning also for dab and fm, or only for digital tv? I have always had problems with dab scanning, but you can get digital radio on freeview (digital tv).
The supplied antenna should be enough to receive at least 50 channels.
How do you scan for channels? What is your PC set up? Have you installed all the drivers?I tried to get it working in my house, out in the garden, even bought a lead to connect the dongle onto my house TV aerial and still says No Signal. :sad:
The same as me I think, couldn't get mine to work either. Win7 or 8 compatability probs?
