Many folk dont have or want a smart ph.I agree with Fisherman about the Victron but for £11 more you can have the same model with bluetooth that lets get see all the battery info on your phone.
VICTRON ENERGY MPPT 75/15 12V 24 VOLT BLUETOOTH SMARTSOLAR CHARGE CONTROLLER | eBay
Most solar panels typically produce approx. Get the Victron Connect App. You can request to have your order left without signature, or to have the order left with a neighbour. SUPPORT HELP LINE! Battery Life.www.ebay.co.uk
The easiest place to find where the starter battery and the Leisure battery connections are close together is by the B2B/split charge/power distribution box. You will be able to tap into both there, plus a ground and fit whatever type of device/wiring to let you charge.
for that size panel, you could easily get away with thinnish cable and 2.5mm2 would be enough. But in relative terms, cabling is a cheap part of the installation and may as well go bigger and put in a bit of future-proofing in case you add a second panel.Yes the cabling looks inadequate, I thought 4mm2 was recommended.
The cabling in the photo looks to small, creating excess resistance lowering output from the solar panel.
Thanks David. I do need to check out the existing cabling before I decide on anything. However the existing controller is fitted in the leisure battery area in the double floor space, so it couldn't be any closer. If the existing wiring doesn't feed the starter battery, its only a metre or so to fish a cable through to the normal Ducato starter battery, just depends whether I can find a path out of the underfloor and under the passenger seat. Thanks again.PS. Looking at the first picture, it looks to me like there are 3 sets of twin-core cable tied together and going to the controller. So maybe one of those is a starter battery set already in place?
Now I will caveat that with a "check carefully"!
On the Adria Twin I fitted a Victron 100/30 to recently, there were FIVE sets of twin core cable going to the original solar controller. The original installer, instead of using a heavier gauge of cable for each connection, used a twin-core black+red for LB -ve, another twin-core black+red for LB -ve, ANOTHER twin-core black+red for SB +ve, and a FOURTH twin-core black+red for SB -ve.
(I didn't use ANY of the existing wiring but something much more suitable).
A wire out through the dash if battery outside, makes sure it is in a bit of tubbing to stop a contact with steel.
Update, I've had a good look at the wiring and there are two heavy + and - from the solar panel and just one feed to the leisure batteries, so that accounts for the 3 wires. I'm thinking of putting a Votronic 1715 Solar-Regulator MPP 250 Duo Dig as drop in replacement which will give me the trickle feed for the starter battery. That will also give me some leeway if we add another panel. If there is no connection back to the van CBE system, I'm assuming that I don't need to worry about matching the maximum rated output from the regulator to the CB516, or am I wrong?? Thanks in advance.PS. Looking at the first picture, it looks to me like there are 3 sets of twin-core cable tied together and going to the controller. So maybe one of those is a starter battery set already in place?
You say "two heavy + and - from the solar panel" - to clarify .... two cables, one + and one -? or they are doubled up and you have two seperate wires wrapped together into the +ve, and two wrapped together into the -ve?Update, I've had a good look at the wiring and there are two heavy + and - from the solar panel and just one feed to the leisure batteries, so that accounts for the 3 wires. I'm thinking of putting a Votronic 1715 Solar-Regulator MPP 250 Duo Dig as drop in replacement which will give me the trickle feed for the starter battery. That will also give me some leeway if we add another panel. If there is no connection back to the van CBE system, I'm assuming that I don't need to worry about matching the maximum rated output from the regulator to the CB516, or am I wrong?? Thanks in advance.
