st3v3
I have a problem that has only started this year, it was fine last year and has been installed for some time.
The setup is:
Shurflo pump with integrated pressure switch
Morco primo instantaneous Gas water heater
Domestic kitchen tap and mixer shower.
Running cold from the kitchen is fine
Running the shower, the pump turns on and off
Turning the kitchen cold tap on at the same time as the shower makes the pump run continuously.
I've removed the shower mixer, blanked the cold and left the hot open, the pump still pulses.
So, I'm left with the water heater is now causing an obstruction or the pressure switch has gone over sensitive.
Anyone had anything similar?
I know @n brown has had a lot of experience with these heaters... Any thoughts mate?
The setup is:
