Power station and Leisure Batteries
I was under the impression one has a lower voltage and must be charged at a slower rate.
And a float charge from solar regulator set for lead acids can shorten lifespan.
Wildbus will know more than me.
Now don't quote me here as I am forgetful and haven't checked. Yes the voltage difference may have an effect but if you parallel a Lifepo4 to an existing LA setup I believe there is no problem. will need someone to conform before yyouacted on this, (David, Merl). I think that the way David does his but as I say I haven't checked and I am forgetful.
The bit where voltage/charging may, (but may not, see what is said) cause a problem is if everything is set to Lifepo4 and you parallel a LA battery to that.
