TrevandJenny
This weeks Coscos offers.
Great for wild camping £199.99
Print
Eccotemp CEL10-Set Portable Outdoor Tankless Water Heater with Shower Set available With or Without Pump
(0)
Item #EccotempCEL10
Starting at £199.99
Features
- BTU: 75,000
- Flow Rate: Rated 10 LPM
- Gas Type: Liquid propane only
- Venting: None needed
- Water Pressure: 1.4 - 5.5 Bar (20-80 PSI)
- Regulator & Hose: 37mbar
- Temperature Control: Manual: 26°- 60°C
Please note: Propane Tank is not Included.
Select option Water Heater with Pump Water Heater
Add to cart
Your estimated delivery time will be 10 business days (excluding weekends and bank holidays) from the time of order. Postcode Restrictions may apply. Find out more in the Delivery & Returns Tab below.
Compare Product
Share
Add to Wishlist
Product Details
CEL10 Manual
The Eccotemp CEL10 Portable Propane Tankless Water Heater gives you instant, hot water wherever you are. The CEL10 is perfect for campsites, cabins or simply around the house. Wash your car, wash your boat, take a hot shower, or even wash your horse!
The CEL10 is capable of reaching temperatures between 26 to 60 degrees Celsius. This model includes an electronic ignition powered by 2 "D" cell batteries making it great for off grid or any location where electricity is not readily available. The ideal operating range for the CEL10 is 1.4 - 5.5 Bar (20 - 80 PSI) with a 10.0 LPM flow. It is compatible with 12-volt pumps and is available at Costco with or without the EccoFlo 12V Pump & Strainer.
When combined with Eccoflo 12V Pump & Strainer you can use water from a river or reservoir as your water source. Simply hook the EccoFlo to a 12V battery and in line with your water heater to setup an off-grid shower. The Eccoflo has a self-priming feature and can safely run dry and you’ll never need to worry about getting air in your lines.
Features:
View More Details
Specifications
Delivery & Returns
Customer Ratings
(0)
Item #EccotempCEL10
Starting at £199.99
Features
- BTU: 75,000
Add to cart
Compare Product
Share
Add to Wishlist
Product Details
CEL10 Manual
Features:
- CE GAR certified
- Battery igniter (2 x D Batteries, not included)
- Rated flow rate approx. 10L per minute
- Up to 18 hours use on 20lb propane tank
- Includes CE regulator for use with standard propane tank
- Includes adapter attaches for any standard garden hose style nozzle
- Adjustable manual water temperature controls
- Standard BSP fittings
- BTU: 75,000
- Flow Rate: Rated up to 10 LPM
- Temperature Control: Manual: 26° - 60°C
- Camping
- Emergency Preparedness
- Off-Grid
- Animal Washing
- Food Trucks
- Outdoor Shower
- RV’s
- Campers
- Pool Side Shower
- Outdoor Recreation
- Hunting
- Cabins
- Tiny homes
View More Details
Specifications
Delivery & Returns
Customer Ratings
