shortcircuit
It is the cab heater that is not working. I have checked the fuses in the engine bay fuse box and all ok. Will check other fuse boxes tomorrow. Thanks for suggestion. In respect of my user name I served a five year apprenticeship as an electrician and I also built and raced single seater stock cars round the oval circuits.
Fix Your Peugeot Boxer/Bipper Heater Blower Resistor Problem In Minutes
You do have to be careful about this because of the fire risk, making sure you only use good quality replacements.
Scroll down Peugeot Boxer (2006-2018) < Fuse Box diagram
Try fuse F57 in the Door Pillar View attachment 70711 View attachment 70712
These iirc were the culprits for all the zafira fires !Thanks for your advice, please check my previous post.
Now returned from France and taken time to resolve matter. Having searched in vain for the door pillar fuse I eventually found details on the web which stated "where fitted" and after looking at the fuse details there would be no reason to fit.
Found various posting on this topic and followed them all through. Put some logical thought into it and the fan motor was not getting 12volts. Fuse 8 in the engine compartment was good which led me to look at the relays as that had been a problem discussed on a forum which suggested a red coloured relay. As there are only 3 red relays I assumed one was faulty but which? I simply rotated all one step clockwise and switched on ignition to which fan ran. I then swaped two over and isolated the faulty relay. Problem solved and hope this may help anybody with same problem.
Will spend all day tomorrow replacing dash panel with a multitude of screws.
