Markd
The fill limit is to allow the lpg to expand without rupturing the bottle.Surely the reason for the 85% fill limit, is to allow room for the liquid to turn to gas?
You should never have the bottle valve open when its not vertical.
If liquid gets past the regulator it won't go back.
Blue flame is how it ought to beIt's all back to normal today although the flame is completely blue,not sure what that signifies.
Yes if there is no open surface no gas can boil off and the larger the area the greater the flow capacity.That is the most important reason but it is also true that if you overfill the bottle the surface area can be reduced to the point where it has reduced boiling potential.
It is known as the wetted surface area, the bottle draws heat through the wall of the bottle allowing the liquid gas to vaporise.Yes if there is no open surface no gas can boil off and the larger the area the greater the flow capacity.
In practice the surface area is constant but draw off rate may fall if consumption is high and sustained enough to significantly reduce the temperature of the liquid and so the vapour pressure above it.
This more common with butane than propane.
I have a small portable bbq that needs the canister to be exposed to fresh air/sun to keep going properly.
Don’t you believe it we had it occasionally with antargaz in France it didn’t happen often but does happenI got the impression that the OP had only just installed a recently acquired refill.
I can't see this being delivered overweight - surely the manufacturers run an automatic check weight on every bottle on the refill line?
Yes, their idea of health and safety is to only use one hand at a time when patching in to the live wires hanging outside a building. Doesn’t make it a good idea.Watched a guy filling bottles in Trivandrum India. There was no observing 80% cut off, he stopped when bottle was full.
Oh, he also had a cheroot in his mouth at the same time. I didn’t hang about to see if it was lit!.
Got an idea they fill ‘em up in Morocco also-
The small bottles anyway- every time I screwed a fitting in a fresh bottle, liquid gas came out.
