You will require a b to b unit and if solar it must have a lith setting, also if you have a mains charger it will require changing.Just swap to lithium half the weight all the power you can get a single 200ah right now on black friday offer that costs less than 2 110ah LA or AGM and weighs way less but gives more power
Lithium isn't as fussy as lead acid WRT charge characteristics Trev and I don't have a dedicated lithium setting on my SCC, you just need to set the float voltage to 13.3-13.5v depending on manufacturers recommendations which you can usually do with the settings. No issues with using a lead acid mains charger either, just don't leave it on float for weeks on end.You will require a b to b unit and if solar it must have a lith setting, also if you have a mains charger it will require changing.
Trev I've never had a B to B in the 6 years I've had lithium and not had a prob with my split charger.You will require a b to b unit and if solar it must have a lith setting, also if you have a mains charger it will require changing.
Why then do somany say required, maybe a smart alt rather than the old type, maybe wildbus can fill us in on that one.Trev I've never had a B to B in the 6 years I've had lithium and not had a prob with my split charger.
Mine is not a smart alternator .Why then do somany say required, maybe a smart alt rather than the old type, maybe wildbus can fill us in on that one.
Jeff is there anything built in to that unit you use that would limit draw if you ever did get very low lithiums? I seem to think there is but can't remember. I know the Yanks with spit chargers on lithium fit a relay to limit current on start upMine is not a smart alternator .
Cheers clears a lot up.If you've got a smart alternator then you need a B2B.
If you've got a standard alternator then it's perfectly possible to charge directly from the alternator BUT wiring resistance is pretty critical.
Most commercial MH conversions will result in a slower charge than Lead Acid (despite the myth about massive currents and burned out wiring), Having said that in a system like yours with heavy cables and a relay charging the leisure battery you'd have to ensure there was sufficient cable length to keep the charge current from going too high when the battery was heavily discharged. Simply a matter of doing a bit of experimenting with a clamp meter and adding some extra cable if needed....OK for the very electrically savvy and well within your wheelhouse Trev but possibly a step too far for most DIYers. Standard advice is therefore fit a B2B or DC to DC as they are also known.![]()
Ive know idea Neil. It's what Phil told me to fitl lololJeff is there anything built in to that unit you use that would limit draw if you ever did get very low lithiums? I seem to think there is but can't remember. I know the Yanks with spit chargers on lithium fit a relay to limit current on start up
I am not sure if it's 16mm cable I use on the split charger or 25 mm Merl it's that long ago.If you've got a smart alternator then you need a B2B.
