LED running lights
Completely clueless about fitting anything into/onto my van. (A 2007 Renault master based Pilote). How easy would it be - or do I need to get it done by the local garage?
I would suggest you would need to get someone to fit them as you will need to tap into vehicle wiring and tools to install.
I fitted ledcom lights to my Autocruise Peugeot boxer. Easy fit by anyone who is competent & can read instructions. :have fun:
I'm sorry, but I disagree. I am not an auto electrician & found it very straightforward if you follow the instructions!
Thanks all
Ledcom look to be best as they will fit existing "blanked off holes" in my bumper.
I Will go to a local autoshop and halfords check ledcom but also others
Just to put you in the picture, on the Renault Master, it involves removing the front bumper, and the nearside headlight. Also, I found that I needed to make a modification, to connect the positive feed. The kit didn't provide the necessary means to do this, without a modification.
Just remembered, to remove the front bumper, you need to first, remove the front grill.
Thanks very much
Thus I will look at alternative lights as well
Lights
Got some LEDCOM ones on order for mine now - will see how the fitting goes! £75 for the in bumper ones via Ebay
I fitted led tail and front side light bulbs fro ebay china,my car had them to and now fitted to my new proton,there brilliant white and dont blow all the time like the old fillament bulbs when shuting hatchback door down.
There buttons to buy and if you want there is button leds units which can be fitted into bumper or rear panel but holes will have to be drilled for them.
