moonshadow
Windows Vista "No audio devices Installed" Soultion ( Descipton) - YouTube this is what i would do first
Thanks, but I already tried that one and it din't work!
This may well not work, but worth a try at least:
Go to Control Panel, then sound and audio devices and check that a device is selected, if not there may be a drop down menu with a device to apply.
In answer to you question 2, rebooting is simply restearting. (ps I am not an expert!)
It it does not show audio device in device manager then its probably a hardware problem, not the driver (or sound disabled in BIOS)
The other thing is Vista being absolutely useless, sometimes it goes wrong and needs a complete restore, after backing up your data.
Could be F8 or F11 or other on start up, consult manual or the net for that. Should recover from hard drive without CDs
If its hardware, alternative is buy a USB sound card. Tiny, looks like a memory stick, think about £5 to £15
I can fix them remotely and would have a look FOC but doubt if I could do anything with it if it does not detect the hardware in the first place!
So it started up but I don't know what i am looking for. I pressed f11 for system information and it has taken me to recovery manager that will restore it to factory settings???? Does that mean I will lose everything on there?
You should be backed up anyhow. It WILL go wrong one day just like us. It's just a matter of which day!
Try resetting the BIOS anyhow, usually F2 to get in there and look for restore defaults, maybe F9 or something. You cannot do any harm it it loads the default values.
Before going for a new laptop you could try an upgrade to Windows 7 (8 is coming out shortly I believe so prices will drop again).
Also there is a software program called Driver Genius which scans for all needed drivers, finds them and installs them for you.
You can backup to the external drive with the vista built in backup but you can also just copy and paste (preferred) so you see whats there before doing it. Then disconnect the external drive before wiping it! Upgrading to 7 is not cost effective and it will not cure the problem if its hardware related. To get in to BIOS is usually F2 (older PC its Del). Try Pause/Break to see if it will pause the start up or look in the manual/on net. Don't panic, just take your time, copy and paste everything on to external drive. Then go for the F11 full restore. You will need to re-install any other applications and printers afterwards. If it does not work after that its hardware. Things can come and go with dry joints or bad connections but unlikely with a built in sound card.
You are really being incredibly helpful...I will turn off and restart and try your suggestion.
