UFO
Just about to order a Renology Pure Sine Wave Inverter.
It's main use will be to charge a laptop. The laptop PSU is a Delta ADP-180MB K output 19.5v DC at 9.23a = 180w. With an input of 240v AC the current should be 0.75A plus a bit for losses in the PSU, say 1A with a good margin.
Using the 'Calculator | AC to DC Amperage Conversion Calculator using a DC to AC Power Inverter' at https://w ww.batterystuff.com/kb/tools/dc-to-ac-amperage-conversion-run-through-an-inverter.html
Drawing 1A from the inverter it will draw 22A from the battery.
I will buy the 1000W inverter to give some future capacity but I can't think of anything else that we might need to use the inverter for. 1000W would provide 4.16A which would draw 92A from the battery. Surge power is 2000W which means 180A from the battery.
I will wire the inverter direct to the battery through the 100A battery monitor shunt. Cable run will be very short.
Some questions
1) Is a fuse needed between the inverter and the battery or is this covered by a fuse in the inverter? Fuse would need to be 200A to allow for the 2000W surge cabaility of the inverter.
2) Is an isolation switch needed between the inverter and the battery or does the inverter on/off switch break the connection between the inverter and the battery? When the inverter is not in use, and is switched off, I don't want it drawing current from the battery. The inverter specifications quote a 'no load current draw of <1A'. Switch would need to be 200A for the reasons stated above.
thank you
Some questions
thank you
