Hymer water system
We have checked fuse and holder and both fine. Our wiring is a different colour to yours but we have checked the blocks you have shown in pics and no power to any of them. It all worked fine when we took a direct power source from else where so maybe we will have to just run a totally fresh power source to the block. Thanks for looking
Do you have a purple wire?, that is the 12v supply feed from the elektrobock, if I remove the fuse then there is no power on mine but by running a 12v lead (with a 5A fuse) to the purple wire at the pump the taps worked as they should
purple wire on block 8 of the elektroblock
purple wire at pump
purple wire at pump
I think it’s brilliant that you are doing this assistance terry ,hat off to you mate again
Took a while but all fixed now. It’s true that old saying that if you need something doing then do it yourself. My main problem was that for once I did not double check the information I was given. When I did , problem solved instantly. The fuse that had been checked was not the correct one so all that messing about was for nothing but many many thanks to all who helped.
May be a silly suggestion but...
... you didn't disturb something for the fridge when you sorted this did you?
