QFour
As for the OP's problem how can they be connected. The fridge ignition system is not going to be connected to the lighting circuit it will probably have its own feed. If everything was working correctly when it went in then it's something they have done. They have trapped a wire and the cable is broken or stuck a screw through something. This will not necessarily blow the fuse it just leave the circuit past the damage without power. With your limited electrical experience I would just take it back and get them to sort it. The fridge not sparking could just be a coincidence or a blown fuse. It could also be switched to 240v / 12v rather than gas. Might be an idea to go exploring and find out where everything is located and what it does. Fuses / Relays / Pump etc.
You could also email Hymer in Germany and ask them for a wiring diagram. At least you will have some info for the future.
