Deleted member 3011
Just make sure you replace the crook battery with the same type because the charger will have been set up to suit. If it is under your seat it is most likely to be either AGM or Gel (both sealed with no easily-removable caps to check water) and since these two have quite different charging requirements, the replacemeent needs to be the same
