Deleted member 775
the water pressure for my cold water is great but when i use the hot water the pump seems to run real slow and i only have very low water flow the water heater is a morco sh 80 storage heater cheers
mandrake said:the water pressure for my cold water is great but when i use the hot water the pump seems to run real slow and i only have very low water flow the water heater is a morco sh 80 storage heater cheers
iam thinking on the limescale side just wondered if any one knows of anything i can put in to clear it idont think a calgone tab will make the tea taste good ha hamerlin wanderer said:If there good pressure on the cold ,the pump is probably ok
the water takes time to heat in some types of heaters
hence it slows down while doing so like combi house boilers
or it could be a limescale ingress in the heater matrix
cheers the only trouble with putting a descaler in is the hot water supply comes from the water tank under the van the same water we use use to drink if i had seperate tanks for drinking and hot water this would be ok unless i can find some product that after i have descaled i can fully clean the system outBiker Jeff said:You could try a Descaling Solution, as you dont drink the water from your hot water system, just the cold.
The water from your boiler should just be used for washing up or the shower i would have thought.
no dont be sorry we are all hear to talk and help cheersjiffers said:thinking about it (this is not going to be of any help by the way) hot water should come out quicker because when it heats it causes pressure but saying that i run clorifier in the t4 so it always has a tank of hot water whilst driving so will build pressure and help it out of the taps sorry
you prob sound somthing similer to mine when i turn the hot water tap on you hear the pump start up ok then a second or so later slows down as if the flow is restrictedDavid & Ann said:Running my water from the kitchen tap is fine. When I run the water in the bathroom it is okay for a few seconds, then trickles out. I have to run the kitchen sink tap again, then go back to the bathroom for it to work again, but runs out again. Have to do this constantly. Any ideas why this happens?
can you not remove the boiloer and descale it then?mandrake said:you prob sound somthing similer to mine when i turn the hot water tap on you hear the pump start up ok then a second or so later slows down as if the flow is restricted
more than likely that is going to be the only cure a winter project i think if all else fails will look round for a replacement cheerswalkers said:can you not remove the boiloer and descale it then?
just a thought but have you checked for trapped pipe work or for any kinks as that could cause the same problemmandrake said:more than likely that is going to be the only cure a winter project i think if all else fails will look round for a replacement cheers
if this is on the m/home i presume it is then i think maybe the switch built in to your bathroom tap may be faultyDavid & Ann said:Running my water from the kitchen tap is fine. When I run the water in the bathroom it is okay for a few seconds, then trickles out. I have to run the kitchen sink tap again, then go back to the bathroom for it to work again, but runs out again. Have to do this constantly. Any ideas why this happens?
i went to the guy i got the van from he said it is most likely the micro switch on the hot tap at fault only trouble is the dam thing looks a sod to get at will give it a go this weekend if i have any luck will post results cheersDavid & Ann said:The funny thing is my tap runs perfectly in the kitchen. It is the only the tap in the bathroom that runs out. I have to run the tap in the kitchen to keep the bathroom tap flowing. I have tested the pump, it is perfect. Walkers suggestion that it could be the switch built into the tap that could be the problem. Could it be the switch in the bathroom tap has had it? Can someone take it from there. I ain't no plumber.
i'm thinking it may be easier to find a replacemant tap don't know where to look for secondhand ones thoughmandrake said:i went to the guy i got the van from he said it is most likely the micro switch on the hot tap at fault only trouble is the dam thing looks a sod to get at will give it a go this weekend if i have any luck will post results cheers
i would think if the pump works ok with the kitchen tap on then that is your problem never had one out so don't know how easy/difficult or even if it is possible to repairDavid & Ann said:The funny thing is my tap runs perfectly in the kitchen. It is the only the tap in the bathroom that runs out. I have to run the tap in the kitchen to keep the bathroom tap flowing. I have tested the pump, it is perfect. Walkers suggestion that it could be the switch built into the tap that could be the problem. Could it be the switch in the bathroom tap has had it? Can someone take it from there. I ain't no plumber.
