On both my PC and laptop keyboards, it's above the 5.
Failing that, though, go to the 'Insert' menu on Word (if you're using Word) and then click 'Symbol'. You should find a % symbol in there.
PS Sometimes, if you type o/o (or 0/0) in, the software will automatically convert it into % as it's not a character stream you would normally otherwise use.
It's not the % symbol that's wanted - it's the degree symbol ° - you can copy and paste it from here if you wish.
There's no easy way to get it using the keyboard sadly ...
Using a standard Windows PC keyboard you can get the degree symbol by using the 'alt' key plus the appropriate numeric code.
You must use the numeric keypad to type the numbers and have 'num lock' on.
The code for the ° symbol is 'alt' + '0176'. i.e. with num lock on, hold down the 'alt' key and type 0176 on the numeric keypad.
Codes for many other symbols can be found here: Windows Alt Key Codes
AndyC
AndyC
The best way is AndyC's way.☺☺It is the quickest.
...or just assign it to a single key, using the method shown. CTRL + ', for example.
I told you it was too complicated to bother with LOLOoop.... sorry! I should learn to read things more thoroughly!
The degree symbol can also be found through 'Insert', then 'Symbol'.
Once you've got it, you should be able to assign it to any keyboard key of your choice. Like this...
Assign a shortcut key to a symbol or special character
Begin shortcut key combinations with CTRL, ALT, or a function key.
On the Insert menu, click Symbol.
Click the tab with the symbol or character you want.
Click the symbol or character you want.
Click Shortcut Key.
In the Press new shortcut key box, press the key combination you want to use. For example, press ALT+ the desired key.
Look at Currently assigned to to see if the shortcut key combination is already assigned to a command or other item.
Reassigning a key combination means that you can no longer use the combination for its original purpose. For example, pressing CTRL+B changes selected text to bold. If you reassign CTRL+B to a new command or other item, you will not be able to bold text by pressing CTRL+B unless you restore the shortcut key assignments to their original settings.
Click Assign.
PS Speaking of keyboard shortcuts, it's worth learning them if you don't already use them in Word. CTRL+I for italics, CTRL+S for save, etc. It saves a lot of time fiddling with the mouse! You can find them all in Help by just searching on 'shortcut keys'. Apologies if you all know all this already!
There is the option to allow the code for strikethrough text (usingIn a similar vein is there a way to get a strikethrough (crossing out) without copy and pasting?
AndyC
One solution for laptops without a number pad or num lock key is to use the on screen keyboard:Joan has just got a new HP Pavilion g series. That keyboard does not have a separate number pad and therefore no num lock key either. The Alt key + numbers does not work in these circumstances. Any suggestions
Start > All Programs > Accessories > Ease of Access (or Accessibility) > On-Screen Keyboard.
Alt codes can be input from there:
num lock > alt > code > alt
AndyC
Hi Andy
Thanks for the keyboard info.
However the screen keyboard does not accept more than a single digit code. ie Alt + 1 to 9 If you try say Alt+128 it shows ☺28 Alt GR plus 4 on the normal keyboard does give € though. Alt GR + a gives á Alt Gr + e gives é the same applies for u i and o
I still cannot fathom how to get the degree symbol using the screen keyboard
Any Alt + 0 codes simply display as blank
Odd, it works for me. The alt key should stay highlighted when you click on it the first time and while you type the numbers, then you click it again to display the symbol on screen.
Caspar's suggestion of using the character map works just as well and gives the possibility to add many symbols without needing to know alt codes.
AndyC
AndyC
