Thanks . . do I put crocodile clips on those wires ? and can I wire more than one light on the same clips or will they need seperate ones ? or would it be better to go through a cig lighter socket ?
sorry electrics not a strength !!
For single connections i use spade crimps like you have on the fittings, for multiple connections i use terminal strip, often called choc blocks (shape).
yes you can wire several off of 1 fuse, just make sure they are connected in parallel so that all the reds are together and all the whites together in anothe block
Remember you don't need to go all the way back to the battery with the white wire... just to the nearest bit of steel bodywork, seat base, floor pan etc.
