Help please,,,,,,,,,,,,
  • Thread starter Thread starter Mothman
Do you think it would work? does it have that extra lead thing Rob???
There is no extra lead just the one cable coming out of the monitor which does everything...power and camera feeds.
Have you got a little used email you can put up and I will send you pics?
Rob
You could always drop it into the shop and I can get our repairman to look at for you.
Hi Rob i have just found out that i need that extra cable it is like the remote wire on a car amp it tells the monitor to switch off and on with the reverse lights,, so i dont think it will be any good unless it has the extra wire Rob?? but many thanks for your offer mate, really good of you,
Rob
Hi Phil heres the problem ive got with the monitor the left hand side of the screen is all fuzzy and pixelated,,,, right hand side ok!!! im thinking the screen is knackered,, do you think its worth your guys taking a look mate??? many thanks,
Thats a shame ......mine was wired up to be on all the time so just turned it off when not needed.
All the best
Rob
Hi Rob ive just got your email, its not gonna be any good i dont think as its not got a power port as i need to connect a power supply for my camera to work,, ok not to worry back to the drawing board,, thanks a million anyway,
Mothman,,,,
Sorry for the lack of response (feeling like poo at the moment :sad::sad:).
The problem with most Mobitronic/Waeco product is that the crafty gits do not use the same pin configuration as the rest of the world. Sure you may find a monitor that has the same 5 pin Mini-Din socket as the camera/cable, but 99% will not have the same inputs/outputs matching the RV27 camera.
Don't rule out a faulty camera cable. My time working on a technical help-dest is that these cameras rarely used to create a fault, but monitors and cables were common (more so the cable as poor installation lead to cables "chaffing" on chassis metal etc). If humanly possible, try to unplug the camera cable and connect the camera direct to the monitor. If the fault has gone, ta da it's a cable and you do not have to use a Mobitronic cable as matching cables are available from other sources. However if the problem is still there, you could really do with someone near to try both items on their set-up.
Failing that, you can contact Dometic directly on 0844 6260133, then go to Warranty and repairs department. They may offer to test the equipment for you and quote repair/replacement costs.
Did try calling them to see if I could speak to someone whom I know that works there, but they are closed for Christmas.
Hi Nick sorry to hear your not too well hope you feel better real soon, many thanks for all your help & advice i will try and get the cable checked out, & thanks for trying to ring the company your a star mate,
mothman,,
