Heating use without water?
Alshymer
Hi
Can you use the van heating when the water is drained down with the Truma gas C4000 system?
According to Truma, all variants of the Truma C series can be used for heating without water. Check you manual to be absolutely sure, but I think all a Truma heaters can be used dry.
My Truma 4 has 4 positions apart from off. 60c water, 40c water, 40c heating and 60c heating and water.
I always thought it was the hot water in the boiler that produced the heat for heating the van - and if you are wrong you will probably burn the element out - but i dont know the answer anyway
My first ever trip in the van, I knew nothing about things like frost valves. On switching on the 12 volt, I lost all my water. Two very cold nights later, and after reading the instruction manual, I closed the valve, refilled the water tank, and had a cosy nights kip.
Relating this to a Motorhome fitter, I was told that I didn’t need water for the heating to work.
As, said fitter turned out to be a bit of a plonker, I haven’t had the nerve, or tbh, the need to try out the theory.
From the FAQ section on the Truma website for the C4000;
The statement "They can be used to heat water and/or warm air alternatively or additionally" would suggest that it is fine to have heating on without water in the system.
If in doubt, give Truma a ring, they can be very helpful.
Mine has 4 positions apart from off: 60°C water; 40°C water; [Off]; heating (with or without water, water temperature not controlled) - denoted by a gas flame alone; heating + 60°C water - denoted by a gas flame together with 60° and symbol for water. So beware, only the one position is suitable for heating with water drained.
Mine is a 2002 truma, I run it every year without water, still works ok and it doesn't have a switch that says heating only
Yes its ok to use heating without water I have a couple of times but somehow prefer to have some water in it
