Heater flue routing/through roof sealing.
Squibby
Hi all,
I have just got hold of a Davey Hot Pot heater for my van conversion, I have decided on the location for the heater in the van its self to provide the heater the best space for heat transfer into the living area, while taking up the minimal amount of useable space, the Davey is normaly used in boats up to 30ft so will be more than enough for my van.
My only concern is how to route the flue through the fiberglass roof and the insulation and cladding whilst keeping the whole thing water proof and more importantly not creating a fire hazard, I have had a look on the Davey web site but the through deck fitting that would normaly be used is more suitable for boat decks with a more solid structure to them(funny that).
Has anyone out there fitted a solid fuel heater to your vehicle and which option did you use for the through roof routing for the flue?
Any help and advice is most welcome.
The flue used is a standard 2.5 inch gas flue in mild steel, I'm sure stainless steel is also an option which would have a longer life and I will be looking into this but it would still be the standard 2.5 inch flue.
Many thanks for your time Martin.
On our mobile homes, water heaters and gas fires we specify that the flue should have a minimum of 25 mm clearance from any combustible surface.
We also specify that on an annual inspection the flue can be readily accessed and smoke tested to ascertain there is no perforation etc.
We use steel plates to surround the flue on its exit to the outside and seal it with a high temperaturee resistant mastic.
I appreciate that all this applies to gas regs so we can issue landlords certificates, but I imagine if you were to do the same with a solid fuel burner/ wood stove etc it would be deemed safe
Hope this helps as a starting point
Channa
Flue Help
Many thanks for the advice I will keep it in mind when I finaly get round to the fitting.
Squibby.
