I fitted two computer fans behind my top vent for the same reason, a switch and thermostat wired in to automatically cut in when required
Alan, we chatted briefly at St Andrews about fridges not coping in excessive heat, like what we had in France this summer. Do you think any type of fan would work, due to ambient temps being high, all it would be doing is pushing/pulling hot air through vents, thus making no difference to fridge cooling capacity?
I will take a couple of photos and a link tomorrow, sorry I have only just seen thisThink I may build one into mine, what temp stat did you use for yours? I see the CAK ones use 30 - 35 deg C ones but reading the ozzy article he's using 60 deg stat
If this is the case, I reckon fan at both ends, one pushing, the other pulling, for best results. Giz a shout, I could knock something up for a test drive. Look at PC fans first, local council tip would a good start.
You have a perfectly good 12v power supply to your fridge that works without the engine running, easy to tap off it with a separate fuse to a switch and thermostat to control the fans, you do not have to go back to the fuse boxProb got a few in the attic, will look at it this week see what I can come up with, I think the hard bit for me is getting power to it ;-(
don't think I can get to it without pulling fridge out ;(( full size fridge freezer built in, will check tomorrow if I can pick it up from the rear at the vents.
I made a quick and simple bracket from a piece of white square drainpipe by cutting a corner a length long enough to go across the top vent then cut along it to make a 1" angle, this slotted behind the top of the vent but was pop riveted on and left lip similar to the one at the bottom, I had removed the complete top vent so that fitting was easier and no mess would go in the back of the fridge, after marking out I fitted two 120mm computer fans,I will take a couple of photos and a link tomorrow, sorry I have only just seen this
You build one and I will beta test it for you, FOCCool (excuse the pun) setup mate and, food for thought. I'd look at new alloy fridge covers, with louvers for air in/out. Fans installed to vent covers. You could also remove fans when not required.
I need to dig out my louver tool, could be a wee earner here.....lol.
You build one and I will beta test it for you, FOC![]()
