Simple answer...Yes, but if you don't use a solar controller between the panel and battery then..
1, you lose about 20% efficiency by not using an MPPT controller.
2, You'll overcharge your battery if you leave it connected after the battery has become fully charged, you need to remove it when the battery voltage reaches say 14.6V. Probably best to buy a cheap solar controller and use that too, a plain old PWM controller won't give you any additional efficiency but it'll save you battery if you accidentally leave it connected.
Our posts crossed1 Cup.. It's got solar controller built in.so,ok then.thanks
It comes with a 30a pwm controller.is this ok.thanksSimple answer...Yes, but if you don't use a solar controller between the panel and battery then..
