Simple answer...Yes, but if you don't use a solar controller between the panel and battery then..mornings.
Can anyone tell me if I can connect a folding solar panal to my leisure batteries,even though I have solar on roof.thanks in advance.
1, you lose about 20% efficiency by not using an MPPT controller.
2, You'll overcharge your battery if you leave it connected after the battery has become fully charged, you need to remove it when the battery voltage reaches say 14.6V. Probably best to buy a cheap solar controller and use that too, a plain old PWM controller won't give you any additional efficiency but it'll save you battery if you accidentally leave it connected.
Our posts crossed1 Cup.. It's got solar controller built in.so,ok then.thanks
If you dont have a sep controler then wire a cigy socket to the input of the one you have, then fitt a cigy plug on the solar output wires and plug in, do mark this cigy socket as solar input only.
It comes with a 30a pwm controller.is this ok.thanksSimple answer...Yes, but if you don't use a solar controller between the panel and battery then..
Yep, fine. A MPPT would give you a bit more charge but it's not a necessity.It comes with a 30a pwm controller.is this ok.thanks
