With regard to the cable entry points, how can the low profile of a flexible panel be maintained, on a pop top roof ?
The reason being, access, under height barriers
This is an example of one I did a few years ago .... IMG_20190701_164133 by David, on Flickr
With this one, I cut the plugs off and fed directly through the roof via a pair of rubber grommets and used some WAGO connectors under the top to connect to cables that went to solar controller.
This panel is a Lensun one and has the panel connector box a little taller than is now typical and a semi-flexible panel youwould get now would be a little lower there.
Of course, it is essential you have all work inspected and on this Transporter here I am getting a Cat Scan .... Cat Scan by David, on Flickr
