molly 2
No danger of the track coming of their is a strong inner panel inside the van that supports the channel .best answer to your question . i suggest that you get it done as soon as practical ,if not the track will part company with the van as the holes that are in the van side panel will have rotted sufficiently to allow the track to become loose .if you can see the rot clearly behind the track as your pics clearly show then the damage will be greater where you cannot see .if the holes rot out you will have a rather expensive job replacing /repairing the panel .as molly says the track is fitted via the inside of the van ,easy to remove on the base van ,but unfortunately a camper conversion makes it more complicated .
