Electric Hook Up Cable
This is what can happen if you don't uncoil a hook up lead. Meks ya think dunnit?
Cheers
H
I have lost count the number of times I have spoken to people about fully uncoiling hook up cables when on sites. Often get a strange look and they state “I have never uncoiled it and it’s been ok”.
Will put this image on my home to show people what can occur.
I would always use a tester, even in the uk never mind abroad.
I have never had a problem in the uk but better safe than sorry.
Using mains electric with reversed polarity is not safe.
A tester will only cost £6-10 pounds and it takes seconds to plug it in and check.
I totally agree with you. But checking the polarity and finding its the wrong way round is one thing.. You then need to swap it back to normal.
The Ebay kit includes the tester as well as the reverse polarity lead and additional hook up leads etc.. all for £35
Its a no brainer really..
I have the same tester. Works very well and having the voltage info as well is a bonus (y)
As an aside, I leave it plugged in 24/7 in the socket by the slider and it flashes every few seconds when the inverter checks for any load so it looks like a car alarm light :)
Just a note. The little short leads to swap the L and N to get the polarity back again are very handy. But .... It is not something you should actually be able to buy as you are being provided with an electrical product that has been deliberately miswired and would of course fail any kind of PAT testing or similar (the fact it is being provided to correct a miswiring doesn't matter - two wrongs are not meant to make a right).
Those are the official rules as I understand them and is why I stopped including these leads as an option for my EHU kits (I tell the customers how they can make them themselves if they want but no longer make them myself as I don't want Trading Strandards at the door!)
For my own van, I no longer use the polarity reversing cable, but have a cross-over switch next to the Consumer Unit
240AC CUs
by David, on Flickr
(as an aside, all MCBs are DP so disconnect both Live & Neutral from the circuits when flipped off for extra security)
I don't blame you in this "sue it society" However, there are loads of these polarity reverse leads kits for sale. Not sure if they need a PAT test as they are not an electrical "appliance" .. a gray area.
Your crossover switch is brilliant but think I will stick to the leads.. :)
Not really that relevant for mains cable but while it is in my head ... If you have any data/signal cables (long network cables, TV Aerial cables, etc) then rather then coil them up for tidiness, go "to and fro" with them so they are not round and round. That avoids any interference on the cable (I remember that from a job many decades ago when troubleshoooting a printer that would randomly print corrupted characters and couldn't suss it for ages. Traced the cable route and under a floorboard by a lift was metres and metres of printer casble coiled up next to the lift power cable. Everytime the printer was running AND the lift was being used, printer printed rubbish. Relaid the cable to get rid of the coil - fixed the problem :)
The prices of that kit lead set in your link is pretty good I have to say :)
The problem is you have too fancy a piece of kit. Us normal plebs carry the cable around coiled and tied with a bit of string.
Carry the EHU cable around in a plastic bag if you like :) most EHU leads are "loose" anyway and not on reel-out spools like the 240v extensions we all use nowadays.
But if you coil up any electric cable and pass an current through it.. It gets bloody hot. Something to do with VIR = volts, amps and resistance = (which causes heat) going back to my school physics days.. solenoids and electromagnetism etc..
When I am camped up on EHU I make sure that any excess cable is randomly "spread about"
A couple of years ago a guy camped next to us and neatly rolled up all his excess cable in a nice tidy circle under his van.. (a bit of OCD I reckon) he then wondered why the supply board MCB kept tripping out.. until I politely explained to him why..
I didn't want it bursting into flames and taking us with it!.
Despite my years I still have to go on building sites to install stuff.. you would be surprised at the amount of times there are fires caused by lazy effers failing to un-ravel even 110v coiled up leads..
I use 25. Not all bays have their own hook up
Better to have a long cable than 2 short ones as often they are driven over and plugs don,t stand up to well to that and for that reason better cheap than expensive cable
I found out that a lot of sites in France have the polarity reversed. (This toasted my Elekrobloc one year). So I bought this kit on ebay. You can test the polarity prior to connecting it to your van and use the "reverse" lead to convert it back.
This is much more handy.
similar(ish), at one of my sites we had all these smart LED lights fitted, looked good but unfortunately they would all do a really quick flicker at the same time, no pattern to it at all and quite a lot of time was used up fault finding. Then a bright spark (fully intended pun) clocked that it happened when the lift motor engaged, micro second of volt drop was not noticeable on the fluorescents, just the LED's. Was never resolved but some things just aren't worth the bother
My cable is 25 meters i always uncoil it fully. The long length has come in handy on a number or occasions, it's surprising the distance you can be from a power outlet on a campsite, some times it's dependent how others have parked their outfit or which outlet they have hooked up to even if numbered to the pitch.
I have seen French ( they seem the worst ) with 100M leads.
DO NOT USE VERY LONG LEADS, the voltage drops and this causes lots of problems.
Never had a problem with 25M good quality copper lead. I believe the very cheap leads are not copper. Bad news.
