Lubrication !!!
This is an update .
Original fault hesitation and spluttering between 1st & 2nd gear , also between 2nd and 3rd gear to a lesser degree on 1993/4 talbot express 170b 2.0l petrol engine.
What we had done/changed
Changed / regapped plugs 0.6mm
changed leads (Brand new)
changed rotor arm and dissy cap for the M130e distributor(the proper Intermotor cap has side exit leads)
Carb stripped and cleaned & blown through 3 times
Fuel tank removed and cleaned + new filters and pipes
new fuel pump
new coil and ignition pack.
NONE OF THE ABOVE CURED THE FAULT.
However , we did a supply voltage chect to the coil/ignition pack and dissy all was ok , so decided to strip the distributor, There was no visiable damage but the Advance weights were sticking to the base plate.
Lack of lubrication -
After a bit of cleaning and oiling and couple of days running around
and a few sleeples nights and a lot of hassle.
"BOBBED" reports problem gone. and running "
PERFECT"
it took a while But another Difficult fault now found.
Thanks to all who contributed.
So Another one sorted.
My Transit Steering Done and BoBbed's Misfire Both repaired and ready to go.
I managed to get away this weekend - Pictures will be on later.
