The ecoflow delta 2 provides 240 volts at 1500w that provides the opportunity to use micro wave oven toaster etc , I have a modern van with poor electrics so cannot fit lithium without major upgrades to my sargent system PS I have lead carbon battery bazzCigy plug sockets are 10 amp max, thats why it melted, dont see any point in having ecoflow if you have proper batteries.
I get the fact that you've got a brand new ciggy socket but that doesn't count for a lot because the positive 'pin' connection especially has very low surface area, they may be ok for lighting a fag but that takes just seconds, your Ecoflow will be drawing current for way way longer.It melted so quickly and badly I have not been able to check the plug fuse it's impossible to remove it
If it was the Ecoflow drawing too many Amps the 15A fuse would have blown before the plug melted. It is far more likely that the heat was generated by a poor contact between plug and socket which caused the plug to melt, which eventually shorted out and blew the 20A fuse to the socket.It melted so quickly and badly I have not been able to check the plug fuse it's impossible to remove it
Did you purchase the Ecoflow using a credit card?Purchased almost month ago, to support my laptop charging as work remotely in my MH.
What a mistake, it drew so much current it melted the 22volt charger plug, fortunately the socket was a ceramic fused outlet and the 25 amp fuse blew.
Lost faith and returned it for a refund absolutely no suggestion the retailer Leroy Merlin in France would rectify or refund me.
No response from Ecoflow as yet and only an offer to return to Ecoflow by LEROY Merlin.
What has your experience been with this unit, views much appreciated
He will still have to prove that the Ecoflow is faulty. A melted plug alone does not prove this because there are other explanations, including the known weaknesses of cigarette lighter sockets.Did you purchase the Ecoflow using a credit card?
If so read the following:
What credit card purchase protection is there in France?
We look at whether there is a French equivalent to the UK’s section 75 rules allowing consumers to request a refund from their credit card companywww.connexionfrance.com
But it was the plug that failed, not the socket.I believe that stated previously the socket was especially installed ceramic type to carry 25 amps and it did not burn or discolour.
I have 2 Ecoflows, both great. I did have to return one after about 1 year and they promptly sorted it.They are all the same, Ecoflow got a big name because they gave them to YouTube influencers
Hi all , I purchased a ecoflow river max ,they informed me that a new software update was available so I downloaded it but it made the front screen blank ,had to contact them! What a rubbish after service. after 6 months of emailing eco flow with no solution other than return to eco flow which I did but still no resolution to it ended in the supplier Jessops giving me a refund .Purchased almost month ago, to support my laptop charging as work remotely in my MH.
