wildebus
UK or Europe? Europe doesn't have an AC system with a different polarity to the UK! it is just it is more likely for the wiring to be WRONG.Eco flow has a built-in charger so it resets to polarity that mains charging cable is plugged into IE uk or Europe ..
Sounds to me that the Ecoflow has a poor design that it will flip flop potentially and you won't know what is going on!
Take the Victron Multiplus I mentioned earlier ... If you are feeding that with a reversed polarity supply, the output will be reversed polarity, as it is passing through the supply - and if need be supplementing it from the battery via the Inverter.
But if there is NO AC supply in, it will revert to the correct polarity (even whilst in use).
THAT is the kind of function you want and is safe, not some "finger in the air" guessing what polarity the output is will be on an inverter.
