Disabling Reversing Sensors
RSD7a
Tow bar to be fitted for bike rack on '23 Peugeot Boxer. Supplier informs me that the spec for compatible wiring harnesses specify that reversing sensors will need to be switched off in the van. The harness won't automatically disabled them on plug in.
The thing is, I've searched the van menus, searched Google and can't find how to manually disable them. The central display is all sat nav and audio menus. The "mode" menu by the drivers right knee doesn't give access to the sensors.
Has anybody managed this with a recent Ducato/Relay/Boxer? Ideas?
As far as I understand, the way that a vehicle knows when it has a trailer (or whatever) is plugged into the socket isn't standardised and varies according to vehicle manufacturers so you're trailor (or whatever) needs to be compatible with your vehicle in order for the auto disabling of reversing sensors to work.
Normally the vehicle is triggered by one of the socket terminals being grounded out (connected to battery negative) so if you do a bit of digging around you should be able to confirm this and find out which pin is responsible for 'sensing'. All you need to do then is to make sure the appropriate pin on your trailer (or whatever) is taken to battery negative.
I guess it's easier for tow bar installers to tell you to turn off your reversing sensors😕
