AlanD
Could someone please explain (in easy terms) what the difference is between a pressurised and a non pressurised system and which is the best? Thanks in advance
Thanks for your answers, so pressurised seems to be the best. Can I use flexible tubing or is domestic push fit better?
This is what I would go along with. I fitted my expansion tank (aka Pressure Vessel) on the water circuit going INTO the water heater though so it is essentially on the general supply and hence works on both hot and cold runs. If you have a pressurised hot water heater then a Pressure Vessel really is a good idea as a precaution (maybe a bit overkill on a van using pumped stored water as max pressure is limited, but a worthwhile precaution IMO).I use an exp. tank on the hot water circuit, but not the cold. An exp. tank should stop any "pulsing" while the water is flowing. Geoff.
