MERL
There seems to be more than 1 issue causing jet/ flame blockage. The vast majority seem to be from rust deposits in the flame tube/ chimney directly above the flame falling onto the jet. Others have reported corrosion in the gas feed pipe with bits of rust blocking the jet from the rear. Obviously for a filter to stop this latter debris it would need to be added immediately prior to the jet, not sure that be would be easy.This is an even cunninger plan. Start at the beginning, why is your gas jet getting blocked? The gas supply is contaminated. Fit a LPG gas filter (not to be confused with American Gas - petrol filter).
Without getting into the area of perhaps you got a duff batch of LPG, I am an experienced gas wallah (not enigneer, it's just vapourised lego). LPG originates from oil, and at the bottom of every LPG tank, Calor or otherwise, there will be a small residue of oil. It can get up the pipe and run towards the appliance. Stick a filter in the way and it won't get to your jet, which then won't get blocked. Assuming some idiot hasn't used rusty steel pipe or disintegrating rubber hose.
Once I went to a house where the customer said my gas hob is making funny burbling noises and the flame goes high and low. Outside the gas supply was two large bottles of Calor and a copper pipe ran along the outside wall, round the back to the kitchen. Some of the pipe clips that held the pipe to the wall had come away, making an effective U bend. The oil in the Calor gas had collected at the bottom of the U bend and the gas had to bubble its way through the oil. It is quite thick. I disconnected the pipe and held the end down to drain the oil. It stinks worse than the worst stink you have ever stunk, and if you get it on your clothes you have to throw them away. Having drained the oil I refitted the pipe properly and the gas appliances in the house all worked fine.
So I suggest you get an in-line gas filter and your problems will disappear. Check your rubber hoses of course.
The price of the filters seems to vary enormously. The official Truma one is Expensive with a capital E, unnecessarily expensive in my opinion. But they do work. This looks OK to me, I would get these from Amazon.
gas+filter&nsdOptOutParam=true&qid=1727341621&sprefix=LPG+filter%2Caps%2C245&sr=8-15
