Kontiki
I'm thinking about getting a second battery, the van is only a couple of months old & the battery fitted is a Yuasa L36-AGM. Having the compressor fridge I was struggling some days even with bright sunshine on the 100 watt solar panel. I would assume it would be best after connecting the batteries in parallel would be to have the positive connection on one battery & the negative on the other battery. To do this I would have to do quite a bit of work to modify the battery box. Is there any disadvantage just connecting the batteries in parallel & leaving both connections on the original battery? The batteries will be close together but the connections from the van wouldn't reach both batteries. Its just it would make it an easy job, i probably will eventually get around to modifying the the box so both batteries would be together. Also what size of wire would be best to use? As to getting another battery I have seen them available at The Battery Shop for £147.
