Bernard Jones
Easiest way to fit terminals is to get the right size for the cable and then they crimp on firmly quite easily in a vice or pliers. - I used these for 25 mm sq cable which I already had from somewhere else 25/6mm Lugs * 10 - Tube/Lugs - Terminals - Raw Components Ltd - Auto electrical Supplies - Specialists in Split Charge Kits
If you can find the d+ wire from the alternator you can use an ordinary relay like this 100 Amp 12v Relay - 12V - Relays & Holders - Raw Components Ltd - Auto electrical Supplies - Specialists in Split Charge Kits
Otherwise you will need a voltage sensing relay will be easiest to fit and least likely to interfere with a modern vans electronic control unit Intelligent "TIMED" Voltage Sensing 100 Amp 12v Relay - Intelligent Relays - Raw Components Ltd - Auto electrical Supplies - Specialists in Split Charge Kits
Sorry about the commercial links – but I can’t see another way to illustrate what I am talking about. I am nothing to do with RAW components, but have bought a few items from them in the past with no problems.
