Moped
Given the van spec, single scooter battery to charge, and storage available to be honest I would probably have done similar. But gone for a bigger 200w solar panel maybe if storage permitted.Sorry for not replying sooner, appreciate all the comments. A few points I should mention, my fridge is a compresser type so gas isn't an option, also the gas locker is only big enough fo a camping gaz 907. I would have liked to get a bigger power pack but space is limited, the EB70 will fit nicely in a cupboard for travelling. My mobility scooter is a Atto Sport with a 249Wh lithium ion battery, it has a range of 20 km. Up to now I've only once got down below 50% so that is an idea how much I use it. As for security for the power pack it would be inside the van (the side sliding window will lock partially open) as for the panel I would secure it with cable lock but restrict use if we had doubts. I thought about fixed solar panel but even then I would need an extra battery, a have a cheap 700 watt inverter that will charge scooter but costs are about same.
We aren't planning doing trips of probably more than 2 to 3 days so no big trios planned.
Took the plunge & ordered the Bluetti EB70 + PV120 solar, they had a sale on & I also found a code to get an extra £80 off.
We have 2 e-bikes with a total battery capacity of around 1000w so needed something bigger battery wise.
The only concern I have is the running of the fridge. Daytime pass through with solar charging you will be OK and you could also top your scooter battery up during this period. When the sun is low in the sky morning and evening and at night the fridge could say draw 600w at around 45w an hour over say a 14 hour period. Assuming the draw is around 45w. For the 8 hours of peak charging you will be OK. Better in high summer of course but then the fridge works harder to offset this. The draw of the fridge needs to be calculated.
Fill it with ice packs before you go away to reduce its energy demands.
Still think fitting a solar panel to the van roof to charge the onboard leisure battery, which presumably runs the fridge, would be worth considering. It will offer you increased flexibility and help to extend your time away.
Is it worth considering a 12v cooler box? Don’t know but their power consumption might be less than the onboard compressor fridge.
Basically see how you get on with the EB70 and solar panel. You can always do further upgrades as and when if needed.
Just curious but how have you managed the fridge power usage before the EB70 purchase?
