tony
I have on hook up and use one of these for the starter battery after getting caught out last year when I was ill did not get to the bus to give her a run and the starter went flat,I have since been using this and the starter always reads fully charged so all good . The one I have is this one AA Shop | Car Battery Solar Charger got from amazon though for 20 delivered
Do get a spark to test the van alt as the rectifier may be leaking back,i have a skoda fabia in my back yard doing this,24 hrs and flat as a pancake.why should I need another charger solar or otherwise.
there is a built in charger that puts in according to laika 2/3 amps per hour maintenance charge into the engine battery.
surely this should be enough ?
why then is my battery running down.
when everything is off there is nothing drawing from the battery.
the battery is not 12 months old yet.
the previous battery again was less then 12 months when it packed up.
tony
Again just guessing as you haven't posted what charger the van has, but usually the chargers put most of charge into leisure battery, the charge to starter battery shouldn't overcharge it.
You appear to be clutching at straws and contemplating a bodge to try and rectify a problem, I would suggest getting it sorted by a professional.
I would use an auto electrician because they would be much better at checking out this problem.i phoned a motorhome repair place i got one of those b####y machines i left my name & number & guess what they never got back to me.
tony
How long are you leaving it for not being used ?
Mine would go flat after about a fortnight
I don't think they're available to buy anymore, I couldn't find out how to buy one anyhow.
These devices are essentially two high power diodes back to back, on a heatsink. No more, no less. Like a pair of electric non-return valves. So the battery with the lowest voltage gets all the charge current until it's at the same voltage as the other battery. I have one that I keep meaning to get round to fitting to the 12v output of the generator.
No, I can assure you that what I have is exactly this device, which IS just two diodes. Current can flow from the in to either of the outs, but not the other way.
My alt states 90ah,anyway i have my unit after the numax charger as in picture,Yes, I did look inside a few years ago.
The docs that come with it (which are not to hand) say how many amps it will take with and without an additional heatsink, but I think it is about 15A as it is, 30A with a big enough heatsink. Not a problem for me: the generator's 12v output is only 10A.
