Your ehu should run the on board charger,if it is only charging service batt and you want engine batt charged to use this cheap splitter unit,mine works a treat.
It can handle up to 16ah so if you have a 10ah on board charger you can put 5ah to each bank,there is an a/b charge wire which one is priority so it will charge the main batt first,so you pick which one.
You can also wire a switch in to divert all charge to any battery,both a/b wire connected,simple.
Looks a nice bit of kit, can I enquire where you bought it from?
Regards Mike
hi to you all experts.
when on EHU is it ok/safe to have the engine battery connected to a separate charger ?
thanks all
tony
to be honest I don't know how it is wired.
tony
Correct i fitted a numax 10ah with 5 stage charging with built in fan,they also do a 20ah model.Yes,
but please use a smart modern charger that is designed to be left connected and unattended.
Old fashioned battery chargers can over charge a battery and also raise the voltage on the vehicle too high and possibly do damage.
Old fashioned battery chargers need to be monitored and not left unattended.
:rulez::rulez::rulez:
Regards Mike
according to laika when on EHU it is supposed to put a maintenance charge of 2/3 amp per hour into the engine battery.
I will have a look in the daylight to see what make charger I got.
tony
What age is it as my 2004 Laika didn't charge the chassis battery on ehu
