Derekoak
When I built my first off grid camper. Batteries were lead. Lead lasted longest if fully topped up continuously. Simple split charge systems common at the time did not do that very well, so I bought a B2B a Ctek ds 250S. Combined smart charger from alternator and solar mppt. Only 20 amp maximum but it kept my 80 amp hour battery in good condition and ran a compressor fridge and other lesser loads.
When I built my 2nd camper lithium was possible but too expensive so I got a temporary 80AGM battery and a Ring Rscdc 30, Planning a lithium when I had run the agm into the ground. The Ring seemed to be like the previous ctek but had 30 amp maximum. It was reasonably cheap and effective (when it worked). Sometimes it stuck and did not charge when the engine started. I took it back to Ring HQ in Leeds a couple of times and they got it going again and Phil @Admin described the reboot sequence, but the Ring was never reliable.
Then Phil and @Harryw went for cheap Chinese Lithum cells for DIY battery making. I decided to tag along. My 2nd camper had space underneath for the battery but not for the usual rectangular battery shapes. I needed squarer and DIY allowed me to do that.
Phil suggested that under the right circumstances Lithium was possible to split charge rather than charge by B2B. This was contentious. His argument was that lithium did not need to be topped up to 100% ASAP for health in fact it was better for it to stay at around mid charge. The expense of B2B was to my mind mainly to ensure full topping up. He showed a system that charged from the alternator with a Victron cyrix li ct. Most others wanted to stay with B2Bs mainly because there were videos put out by Victron showing smoking alternators caused by uncontrolled charging.
@trevskoda said that his system was even simpler just a manual switch to trigger a power relay to join leisure battery to starter battery when he decided. He said alternators were under most load at startup so he switched his switch after a few minutes.
I did a test temporarily joining my starter and 120amp alternator to my lithium battery at 12.9volts with a 16mm copper cable. At idle there was 59amps at 2000rpm 66amps. I decided that I was unlikely to damage my alternator and copied Phils system.
I got my extra complications sorted, heater circuits for the lithium cells when cold, especially needed with an underslung battery. Since then my system has been working well. In fact too well! My 200ah battery is nearly always full! This is maybe not good for it. So recently I installed a switch in the cab switching the cyrix signal wire. So now:
if I am not using my doblo as a camper (fridge off) I have this switch off and the alternator does not charge the lithium, (I have a bypass wire to switch the signal wire on when the ignition is off so that my solar can top up my starter battery)
If we are camping but solar is good the switch is off if the lithium SOC is below 75% as experience shows that my 160watt solar can keep up with our demand in good conditions. This must save a bit of diesel.
Finally, copying Trev, the switch is off for the first few minutes after starting to reduce strain on the alternator even further.
So this means that the switch is off more than it is on. I do wonder whether the cyrix Lict was unneccessary too. If the switch is fed with ignition positive even if you inadvertently leave the switch on when you stop the engine, the leisure battery still disconnects from the starter battery when the ignition is off. The cyrix may be cheaper than a B2B at 80 pounds, but a power relay only costs 25 pounds.
Anyway for me a B2B has been shown to not be needed with my Lithium.
