master
Hi, I am having problems with my Dometic 3-way absorption fridge not getting cold enough recently. Done the usual stuff and cleaned the flue and burner and tipped it upside down (really this is meant to help and it did a bit). So it does cool somewhat but not brilliantly and certainly not enough for sunnier climes. So it looks like it might be a new 3-way fridge at around £550 - £600 or a same size compressor one at £750 ish (ouch!!!).
Well I have never been too impressed with the absorption fridge getting cold enough, even with vent fans, so the alternative is a compressor fridge. But we do mostly wildcamping and never have EHU, so even with solar panels I am worried about battery drain over 3 or 4 stationary and dull days (even with 2x110Ahr batteries and 2x90W solar panels). You know that perennial fridge debate: compressor vs absorption and which is better!
So.... here is the thought: Why is there not a 4-way fridge that combines a less efficient gas absorption unit with a 12v compressor? Whilst driving, or on EHU, or when there is lots of solar (and likely the ambient temp is higher)) it uses the efficient 12V compressor, and when there is no freely available 12V power (eg its dark and likely the ambient is lower) it uses gas - which is blissfully silent overnight. Has anyone come across such a unit - sounds to me like it would solve the perennial compressor versus absorption fridge issue and give the benefits of both.
Now.... since I have a self-build van and I fitted a secondhand fridge (perhaps thats why its not working too well - its a bit old and tired), and as chance would have it I could only get a step/ wheel arch fridge. Now that gives me a space under the rear of the fridge and I think I could fit a Waeco CU55 compressor cooling kit in the space and mount the evaporator plate inside the existing Dometic 3-way - again I think it will fit. The Waeco kit is about £350 so less than a new fridge (my existing cabinet is fine) which would be good. All I would need to do is re-route the 12V (which comes from a relay switched by the alternator - so only supplied when the engine is running) and 240V (from EHU) to to the compressor - perhaps do some magic with the solar so the compressor gets 12V when the sun shines - and voila my "4-way fridge". Ok the gas is still not brilliant (and would still need to be lit manually) but probably OK to maintain the temperature overnight and on dull days.
Any thoughts on this slightly wacky idea? Anyone done such a thing? I wanted to sanity check this before I go hack my fridge apart - if I do and it works I will let you know.
BTW the Waeco CU 55 compressor unit is just a stand alone refrigeration unit that has no cabinet and is designed to allow you to build your own insulated box with a evaporator inside - a 'diy kit form' fridge if you like - looks a pretty neat unit.
