Chrisb1701
the NASA BM models have a lot of fans and one of the key features with them is the Big Display. they are a fair bit easier to see then the Victron BMVs (the display on the BMV is perfectly readable still. you just have to scroll through to see the different info).I am thinking of installing a battery monitor
Does anyone have one installed are they worth installing any recommendations for make or model ?
I was looking at the vitron 712 with Bluetooth
No question. MUCH SUPERIOR.Hello
I've an Auto-sleepers fitted Sargent ec480, are the mentioned displays superior in any way?
Graham
The voltag
It depends what you want to monitor. Monitoring the voltage is easy, but pretty useless on its own.
The voltage of a battery is only an indication of its remaining charge if no current has flowed in or out of the battery for the last hour or two. Which makes it an impractical measure, even though many people on WC seem to think it tells them something.
In theory you can calculate the state of charge by measuring both the voltage and the current, but the reality is that this is never accurate either, even with fancy calculations involving Peukert's formula.
The only worthwhile way is to monitor the current going in and out and try to keep track. This is fairly reliable as long as the battery is charged right up to the top fairly often, or run right down flat (not recommended!) However accurate they are, small errors can build up, so getting up to 100% from time to time helps keep them accurate.
As far as I can see, the Victror 712 is one of these, with the addition of a bluetooth bit to provide connectivity to an app.
The one I use (which works brilliantly, and has done for many years) looks exactly like DC Battery Monitor Positive Negative Current +/- 30A Voltage 120V Car Volt Meter 754610748905 | eBay which costs less than £15. But if you would rather pay more than ten times as much to be able to open an app instead of looking at a display, that's fine by me!
[Later] Mine must be a bit different because it measures charge currents way over 30A. Perhaps mine is a 50 or 60 amp one. I don't remember, to be honest. It was installed many years ago.
I've not used a smartguage, but although I accept most of their criticisms of amp counting meters, I consider their smoke and mirrors calculations to be dubious at best.
Far better to accept that no battery monitor is 100% precise, and to try to get the batteries up to (and past) 100% full on a regular basis. That way the "counting meter" resets itself and is far more accurate than the smartguage which is only guessing.
Of course, the capacity of your battery bank is an unknown in the first place. Yes, each battery may be.nominally 100Ah, but that will only be when it is brand new, at a temperature of 25°c and a discharge current of exactly 5A, and subject to production line variations.
Those conditions cease to apply as soon as it is installed and/or used. You have to use an informed guess to decide what your battery bank's capacity is. You could never be 99% accurate in that, so their quibble that ammeters can often be 1% out is silly.
I use the term "leisure" battery to distinquish between Starter Batteries and Traction batteries and the ones targetted to the RV & Marine industries rather than a specific subset.I'm sure you are right. To be quite honest, I wouldn't buy a "leisure" battery in the first place. Normal batteries tend to be a far better buy, if you can't afford Deep Cycle.
I had a read of the Smartgauge link. I've never used one either and felt the write-up was heavily biased towards a "we're great, the rest is rubbish" angle and was hardly impartial. I would like to read an independent review on the product.I've not used a smartguage, but although I accept most of their criticisms of amp counting meters, I consider their smoke and mirrors calculations to be dubious at best.
A fair observation, but for me, analysing is a hobby of mine :idea-007:, so me doing this (and getting 'toys' etc, that are not maybe really neccessary) is part of the fun and enjoyment of the whole campervan thing.So to top things off 90% of folk on here are battery gauge watchers rather than go out play,if mine die i buy new ones,but im still going out to play,na na na na.:drive:
I think mine is probably a 60 amp one. It seems to be OK.
I have one of those. Seems to work OK for the things I've tested through it, but it is really more of a test tool than a thing to use as a display.
I suspect I have a DC one of these too, but I've never even tried it. I didn't think it measures to and fro current: only shows one direction, which is not what I was looking for at the time. But perhaps it does work with "negative" currents. Can you confirm?
Single Direction only. You can reverse the two sensing wires to read reverse currents. I have used a pair of these with a single shunt, but with one set of wires reversed. You can in that way read the power/current and total power in; and the same again for outbound. Doing this can actually provide more info then many bi-directional meters
That looks interesting, but in general I'm not keen on stuff that uses wireless links. Goes out of date too fast, or just goes wrong. Your subsequent review is what brought me back to look at this thread.
Ref wireless. I am not sure what that is about TBH. there is the little wireless-style symbol in the bottom corner but it is not a feature I am using. The hall sensor and a temp sensor (nice touch having that as standard - the Victron temp sensor costs the same as this whole monitor!) connect to a control box and the monitor connects to the control box via a USB Lead. The Control box also has 2 or 3 relays built in which is a nice touch.
I reckon you can ignore the 'wireless' feature. The downside to this unit is you have to have the monitor pretty close to the battery (unless of course, you used a USB extension lead which I think would work ok). I'll maybe look at the wireless bit, but only out of curiosity rather than neccessity.
That looks good. On my similar monitor, the only setting needed was to select the shunt size (50A or 100A), so one button was good enough. Your linked one will of course need setting up for battery bank size so I guess the buttons will feature as up and down amongst other uses.I wonder how similar that is to this one: Battery Monitor 6in1 300V 100A State of Charge SOC AH VOLT AMP Charge Discharge 732140263808 | eBay which seems to be more what I wanted. They do look quite similar in the display, but yours has one button and the one I found has two. What do you think?
£50 for a BM-1 is a great priceWhilst it's a great piece of kit, I may have a BM-1 for sale at/after the New year meet at Hereford, for £50. I need to have a chat to Phil
Just in case that helps anyone out...
