As You all know I've recently installed a 100watt solar panel with 10 amp controller, what size fuse would you recomend down at the battery end, 15amp, 20 amp or any other size.
Thanks for yor help.
John.
I think this is right
Amps = Watts / volts so theoretically your panel can provide 8.3 amps. a 10amp fuse should do the job.
And if the cable used is rated at 5amps you have a fire!
Correct but that was not the question![]()
I dont see how. The fuse is there to protect the cable and if you do not no the size of cable then you cannot suggest a size.
One would hope that he has read your first post about the cable and has the correct cable for his panel , But regardless if he fits a fuse lower than the panel is going to supply it will blow anyway. Chicken and Egg the 2 go together IMHO and both should be suggested together.
And what about the power the battery will supply back up the cable in the event of a fault in cable?
But 10 amp is still the smallest fuse you can fit (well 8.33 but they don't make those). Hense having the fuse at the battery end but you know this.....
Assuming they are spade fuses
Box of Car Spade Fuses
Set of 80 fuses for automotive use.
Contents
* 10 x 3A Fuses
* 10 x 5A Fuses
* 10 x 7.5A Fuses
* 10 x 10A Fuses
* 10 x 15A Fuses
* 10 x 20A Fuses
* 10 x 25A Fuses
* 10 x 30A Fuses
* 1 x Tool
The fuse must be less than the rating of the cable and not just what is available
No one is disagreeing with you, but the fuse must also be large enough to cope with the current produced by the solar panel. Its not a radio or similar that is just going to 'suck' power it is also going to produce power (if the sun ever shines).
If his solarpanel produces 8.3 amps then the fuse MUST be bigger than this even your list above shows that 10amps is the smallest vehicle fuse he can use.
But I'm bored with this if you don't get it now you never will![]()
Thanks Biggiraf, and shortcircuit, I have used the proper cable the same as comes with solar panel, so I will fit a 10 amp fuse. The reason I've asked the original question is a mate of mine is a auto electrician and he supplied and fitted fuse holder only, and he has fitted a 30amp spade fuse which I considered was to big. so thanks again guy's, didn't mean for you to fall out though.
John.
To prevent a fire due to overheating of the cable in the event of a short circuit.I may be missing something here, but why do you need a fuse at the battery end?
bev
John.
