fatgaz
having just fitted a new thermostat in my fiat ducato/i have still got a problem as when my van is on tick over the cooolent start to bubble and spit out of the header tank could any 1 help me on this please. fatgaz
Sounds like air in the system to me try switching off when hot and squeezing the hoses to shift the air lock and when cooled down top up header tank.
If the problem was only after fitting thermostat that will be your problem![]()
Head gasket sounds serious ****zer.....I hope not, and hope the technically competent have given sound advice.
Channa
If the head gasket is gone then it is a hell of a coincidence that it happened whilst changing the thermostat.
That will be "mayo" then!the oil filler cap, this might be full of white emulsified oil / water mixture if the gasket has blown.
One place thet can give it away is to look at the inside of the oil filler cap, this might be full of white emulsified oil / water mixture if the gasket has blown.
No doesnt always mean that,the cold will turn it that colour.Try the rocker cover first take that off and then you will know!
Some vehicles have a specific routine for filling the cooling system, an extreme example is that a few years ago some renaults needed to have the front end of the vehicle to be raised when refilling, my local garage used to do this in an extreme way by placing the front wheels on the lift and raising it to the required angle. My sons current car has a "hidden" bleed valve and it is impossible to get things right if it is not openned when filling.
The best advice is to read the workshop manual.
hi all just like to say thanks for your help, went out today and checked the oil that seem fine blead all the cooling system, put a new seal on the header tank cap, and it seem to ok now, so once again thanks for your help, you may see me asking for help again as i just got this camper van and dont know a lot about it lol thanks
